I can"t find my seacock!
- Loria
- Vessel Info: 1993 carver express
- buster53
- Has thanked: 8 times
- Been thanked: 253 times
Re: I can"t find my seacock!
Most likely, all of your through hulls will be in the engine room. Find all of them and follow hoses to figure out what each is used for.
Make sure all seacocks are open and try flushing again. Make sure your dockside water connection is off and your water system pump is off as well. If you are getting water to the head, it is raw water. No water, turn on your dockside water and try again and if it works this time, you have fresh water flushing. If still no water, you have a head issue that may require a rebuild kit. Don't panic as it is a fairly simple fix for anyone who can turn a screw driver and wrench set. It will take an hour or two for the rebuild.
- RGrew176
- Vessel Info: 2022 Stingray 182 SC
- Has thanked: 72 times
- Been thanked: 464 times
- Hold'n On II
- Vessel Info: New to us 1996 370 Voyager
- Been thanked: 10 times
https://carveryachts.blob.core.windows. ... _93_v2.pdf
By the looks of it, somewhere under the head itself, or just aft under the port side access hatch under the bed in your mid cabin (see page 44/43).
