Closing engine vents for winter
Has thanked: 60 times
Been thanked: 261 times
Re: Closing engine vents for winter
Postby Midnightsun » October 5th, 2018, 4:33 am
Sailor Jerry wrote:Source of the post I'm on the Tennessee River. Temperature will only drop below freezing occasionally. The boat stays in the water all winter, so I'm trying to keep the cold air out.
Ah, I see said the blind man to his deaf wife. :-D In that case I would make up some nice Sunbrella covers with snaps as mentioned elsewhere in this thread.
Vessel Info: 1989 Carver 3807
Has thanked: 108 times
Been thanked: 522 times
Postby Viper » October 5th, 2018, 7:09 am
Sailor Jerry wrote:Source of the post If shrink wrap will keep the cold out, that sure sounds easy.
If you're going to use shrink tape against your hull, use preservation tape instead of the regular stuff. It won't leave any glue residue on your hull when you remove it in the spring.
denpooch
Vessel Info: 2005 360 Mariner
Crusader 6.0 Captains Choice
Has thanked: 43 times
Been thanked: 42 times
Postby denpooch » October 7th, 2018, 9:24 am
I second Mike's (mjk1040) comment. I store my boat on the hard, outside in the elements, covered by shrink wrap. It's gonna get cold in the engine compartment anyway so I don't understand the concern about 'keeping the cold out'. I'd be interested in understanding the thinking behind the procedure. Thanks.
dabluzdude
Vessel Info: 1991 33AC
Been thanked: 2 times
Postby dabluzdude » October 7th, 2018, 2:47 pm
Most likely, the boat is not "winterized" as you would think of it, being from New York. This boat is left in the water with a bilge heater to protect it from freezing, if/when the temperatures dip that low. The covering of the vents helps keep the heat from the bilge heater in, and the cold wind out.
Sailor Jerry
Vessel Info: 1996 Carver 355
Postby Sailor Jerry » October 7th, 2018, 9:20 pm
I would like to use the snaps, they just don't hold the covers. About half the snaps are fine, but half are too loose and the cover falls half open. I wonder if there is a way to correct this? It would be easier than making something else, since I already have covers.
Has thanked: 3 times
Been thanked: 132 times
Postby g36 » October 7th, 2018, 9:41 pm
if the actual cover is ok then reuse it and snaps are easily replaced on both the boat and cover. if on the cover you can drill out the center of the snap and then reinstall new ones. use something like this inexpensive kit
link it not posting but go to amazon and put this in the search its $15.00
62Pcs Stainless Steel Fastener Screw Snap Kit in Storage Box, Marine Grade, 3/8" Socket #6-5/8" with 2 Pcs Setting Tool
AaHubb
Vessel Info: '99 404 CPMY
my twin diesel pusher
Has thanked: 8 times
Been thanked: 38 times
Postby AaHubb » October 8th, 2018, 10:19 am
Seadragon spends the winter in her slip so covering the vents is helpful. I made a pair of covers using outdoor plywood that fit into the recessed area of the vents. Some eyebolts and bungee cords threaded behind the grills holds them in place.
..Aaron
'99 404 CPMY
SeaDragon
Sailor Jerry
Postby Sailor Jerry » October 8th, 2018, 4:26 pm
Thanks to all who responded. It isn't that I don't like the snaps. About half of them are worn, I guess, because they fit so loosely that the cover falls open.
Tireless
Volvo Penta D6 370 HP
Been thanked: 5 times
Postby Tireless » October 16th, 2018, 5:30 pm
I am in Port Severn, Ontario, Canada and I cover my vessel with a Genco cover that I had made for it. It covers the vessel from the top down to the chine. I have never put a cover specifically over the side vents. I was always of the belief that the vessel should be allowed to breath through the winter to not trap moisture in the bilge. I might be wrong about that, but I also open up a couple port holes in the cabin as well. Interesting topic, as I spoke about this with a boater friend this morning prior to reading this post. Would be interested in hearing why you would cover these vents. Maybe something to look at.
Has thanked: 247 times
Been thanked: 381 times
Postby bud37 » October 16th, 2018, 6:12 pm
Tireless...Welcome to the forum....they are talking about boats being left in the water for the winter and keeping the heat in and the cold out, much like your house.....unlike us, who are totally winterized with the boat in the parking lot, we just need to ventilate a bit and keep the critters out........ :beergood:
Users browsing this forum: Cooler and 8 guests
