Door removal
- Agriman
- Vessel Info: 1998 Carver 350 Mariner Twin 454 Crusaders
- Has thanked: 5 times
- Been thanked: 5 times
Door removal
- Been thanked: 1312 times
Re: Door removal
- jonny12
- Vessel Info: my vessel is 2003 Carver Yacht 366
- Has thanked: 3 times
Re: Door removal
Safety First: Ensure the boat is securely docked or anchored, and the area is well-lit to prevent accidents.
Clear the Area: Remove any obstacles or items that might obstruct your access to the sliding door.
Remove the Door Handle: Most sliding doors have a handle that can be unscrewed or detached. Remove the handle first.
Check for Screws and Fasteners: Look around the frame of the sliding door for screws or fasteners.
Lift the Door: With the fasteners removed, gently lift the sliding door up and out of the track.
Inspect and Replace Insulation: Once the door is removed, you can access the top track and replace the insulation as needed.
- jonny12
Re: Door removal
