Strainer bummer
Has thanked: 58 times
Been thanked: 454 times
Strainer bummer
Postby waybomb » May 8th, 2025, 5:13 pm
Discovered my boat doesn't have engine strainers. The genny does. The ac does.
How did I find out? Access to the slips in front of my condo from the north is shoaled in. Was going very slow but grounded it in sand. Was able to back out. Marina owner was with me as a second hand if needed.
Headed back to put it one of his slips. Starboard engine started getting warm. Had water flow out the exhaust, but temp got up to about 175 after about 10 minutes of heading back up the river. Revved the engine a few times but didn't clear it. Shut the engine down and came in on one.
Yesterday went to the boat to clean out the strainers. All my boats have strainers, right? Nope.
So now I'll be removing the thermostat and block drains in an effort to clear sand. Then replace the impeller. Then install proper strainers on both engines.
Never a dull moment.
Has thanked: 585 times
Been thanked: 1242 times
Re: Strainer bummer
Postby bud37 » May 8th, 2025, 6:47 pm
Maybe ya just destroyed or severely damaged the impeller in the raw water pump....back flush anyway but just a thought.
FWIW.....The above is just my opinion..... :popcorn:
Re: Strainer bummer
Postby waybomb » May 8th, 2025, 6:58 pm
Yup, I'm pretty sure both impellers will need replacement. I have one set always on the boat and another at home asking with the wedge pieces so i won't have to wait for parts
Been thanked: 243 times
Re: Strainer bummer
Postby mjk1040 » May 10th, 2025, 4:05 am
Some boat engines did not have strainers on them, if you are going to install strainers make sure the size and flow rate is attiquit for your application, :beergood:
Re: Strainer bummer
Postby waybomb » May 10th, 2025, 1:28 pm
Took starboard pump off. Sand packed in the outlet holes. Impeller was fine. Housing and wedge fine. Cleaned it up. Replaced impeller. Replaced hose to oil cooler. No sand in cooler. Took cover off of thermostat. It's fine. Very little sand came from either side of engine. All good.
I'll mess with the other side tomorrow.
paulr
Vessel Info: 396 CY Aft Cabin 2001 8.1 Crusaders
Has thanked: 40 times
Been thanked: 22 times
Re: Strainer bummer
Postby paulr » May 10th, 2025, 2:22 pm
Strainers? I had a 34' Luhrs with twin Marine Power gas, 454 GM blocks and it never had engine strainers.
My Carver 396 has twin 8.1 Crusaders, gas, did not come with engine strainers.
The generators and A/C pump did have strainers. You are not alone.
Re: Strainer bummer
Postby waybomb » May 10th, 2025, 2:35 pm
I'm redoing my offshore boat. Going from 3 engines to 2 engines. Installing a completely different cooling system, so I have 3 perko strainers with the flushing inlets on them. I'll probably have to buy some fittings, but other than that, a free upgrade.
Re: Strainer bummer
Postby bud37 » May 10th, 2025, 4:57 pm
Heh Fred, does your boat have the remote v drives with the shafts or attached directly to the engines? Strainers are good at keeping grass and debris out but do you have to pull water thru the v Drive etc.
Re: Strainer bummer
Postby waybomb » May 10th, 2025, 5:01 pm
The v-drives are driven by short driveshaft from the transmission.
Yes, the water goes through the v drive before it gets to the engine.
Sea cock, then v- drive, then engine.
Users browsing this forum: Google Adsense [Bot] and 52 guests
