Thru hull transducer leak
- Merkinbrumsky
- Vessel Info: 1985 Carver Voyager
- Has thanked: 53 times
- Been thanked: 38 times
Re: Thru hull transducer leak
- Merkinbrumsky
km1125 wrote:Source of the post I'd be a bit wary of cranking down on old plastic parts that are below the waterline in an attempt to stem a leak. The best way would be to remove it, coat with something like 4200 and reinstall and tighten "snug" (not overly tight to strain the plastic). But I'd probably only do that if I actually had to use the old part. There are some blanks out there that can be used to close-off a hole that's been previously used, but I don't have a quick link to point to. You can also add an appropriate thru-hull and just cap it inside the boat.
Thanks, ya…I was nervous about tightening that as well but I didn’t have to really crank on it. I would say I just snugged it up lightly hand tight without much effort. I’m sure if I cranked on it I could snug it up more but I thought better of it.They do have “wings” on either side to hold onto with tightening/loosening arrows and specific directions to not overtighten. I can’t seem to find a pic of a similar one online. Once the boat is on the hard I will dig further.
- Merkinbrumsky
- Has thanked: 602 times
- Merkinbrumsky
km1125 wrote:Source of the post That looks like an old DataMarine, either speed/log or depth.
You win!!! lol..,datamarine depth sounder
Users browsing this forum: No registered users and 42 guests
