Prop Size Dilemma?
- Has thanked: 547 times
- Been thanked: 1143 times
Re: Prop Size Dilemma?
- mjk1040
- Been thanked: 236 times
1996 Boston Whaler Rage 15 - Location: Saint Joseph,Mi
- Has thanked: 50 times
- Been thanked: 397 times
My buddy had a32 montego years ago. I did not like driving that boat. I think it had this wander you are speaking of.
Topic author - Scurvy Dog
- Vessel Info: 1998 Carver 350 Mariner
- Has thanked: 22 times
waybomb wrote:Source of the post I have a spare set of 22 x 22 x 1 3/8 you could try if you want.
I'm almost next door to Pier33.
Thanks Waybomb for the offer. Unfortunately, our shafts are 1 1/4".
TonyC
TonyC
- SanJuanDreamer
- Has thanked: 1 time
- Been thanked: 21 times
Good post as my Mariner likes to wonder at slower speeds, thought it might just be me...sounds like that's the design.
- mjk1040
TonyC wrote:Source of the post All,
Pulled the props on our 1998 350 Mariner. Prop shop clean and scanned and told me that I could get another year or so
out of them after a tune-up. However, due to age and that they are brass, should not expect much more life out of them.
They were concerned about the props and boat configuration. Current props are 4 blade, 20 x 23. Boat has twin 350 MAGs MPI at 300 HP. with V-Drive 1.5:1 ratio. They tell me that the "number" crunching suggests that we should use 4 blade, 20 x 21. They called and did confirm with Carver that the boat came with the props that I took off. The prop shop asked what my WOT RPM is and, while I did open it up a couple of times it was not for a long duration. I believe that the tachs were over 4000 but by how much I do not recall.
We rarely cruise more than at plane ... around 3000 - 3200k. What can be a problem and is a concern is at low RPM while docking. We need to fight a current and wind changes. With the current props the boat responds sluggishly at best without adjusting the throttles (which I prefer not to do while docking). The way I understand prop and prop design, the 20 x 21 should provide more thrust at lower RPM's providing better response while docking.
Any thoughts on this? Should I pull the trigger on the suggested new props (brass and other alloy combination at $3100 for both) or go in a different direction. We love this boat and plan to keep a long time. Thanks!
TonyC
Tony another thought here, if those props you have are original at 20x23 then the shop can knock them down to 20x21 ,as I understand it you can go up or down 2 pitch numbers, not quite the same as new 20x21 ( not sure what the cup might be), ask your shop about that if that would be something you might want to do.......
- jswampy66@yahoo.com
- Vessel Info: 2002 396 carver cummins 370 6bta
Users browsing this forum: No registered users and 42 guests
