Rear Aux. Tank in 355/356 Carver AC/MY
- mjk1040
- Been thanked: 236 times
Re: Rear Aux. Tank in 355/356 Carver AC/MY
- Has thanked: 431 times
- Been thanked: 1586 times
mjk1040 wrote:Source of the post Well the fill, vent and pickup ports on the tank are all 90 degree elbows....
I thought that was the case, that's why I mentioned it. Worse comes to worse, go through the sender, that's what I did and it wasn't that bad to get at. From there it's just straight down and you have some wiggle room to move the hose around.
- Has thanked: 547 times
- Been thanked: 1142 times
mjk1040 wrote:Source of the post Then most likely out some soapy water in the tank and pump that off a couple of times
Mike, Just a thought.... would that be wise considering water is what probably gets these things to corrode in the first place....possibly make it worse unless you are going to get the tank out of there quickly. Also you will be stuck with gallons of gas and water.
- mjk1040
- Has thanked: 313 times
- Been thanked: 581 times
tomschauer wrote:Source of the post .....Diesel will smell forever!
+1
- mjk1040
mjk1040 wrote:Source of the post Yes I agree soap and water!
Yup, I think that is better .The diesel sounds like you might go from one problem to another.....again good luck man..
Users browsing this forum: No registered users and 53 guests
