Windless issue
- 390Express
- Captain
- Has thanked: 141 times
- Been thanked: 15 times
Windless issue
I have power to the helm switch, and power is getting to the windless, but the solenoid switches located near the windless seem to be bad. There is a fusible link that has some corrosion in it (that I will replace), but the fuse is good, I cleaned it off and added some dielectrict grease to it and power seems to be getting past it. The solenoids are located inside a plastic, sealed box with the brand name of the windless on it. Do I have to buy that same plastic box and solenoids, or is it safe to install loose solenoids and wire them separate? Windless motor engages when I give it power.
I thought the brand started with an S (sea star possibly), but should have taken a pic. I'll have one this evening.
