Carver Mariner 350 Bed mattress issues
- amanphoto
- Has thanked: 3 times
- Been thanked: 12 times
I have not mentioned the large wedge shaped space at the top bed, between the mattress and the chain locker. The mattress is flush to the wall on the starboard side and is about 12" away on the port side. There is a shallow fiberglass wall (hump) that hold the mattress in place but is large enough to loose some pillows in at night. We sleep with our heads at the bow and end up stuffing some pillows in there.
I'm out of my mind....
The plan is to make a new mattress over the winter. My questions are as fallows...
1. Is there a minimum foam thickness or foam layer formula for building a foam mattress? For example so many inches of foam #, then so many inches of foam #, then...
2. Do I make the mattress go over the fiberglass hump at the top of the bed? If I do, I'm going to need custom made sheets.
3. It's a custom shaped bed. The starboard top corner is rounded to I'm going to have to trim the corner off. Also the starboard edge is tapered. The thicker the bed is, the more space (gap) there is in the starboard side.
What have you done to make a comfy nights sleep? Any make a custom mattress for their Carver? I don't want to put a sock twin mattress in there. It will not match the contour of the boat.
- Has thanked: 313 times
- Been thanked: 581 times
Re: Carver Mariner 350 Bed mattress issues
- RGrew176
- Vessel Info: 2022 Stingray 182 SC
- Has thanked: 72 times
- Been thanked: 464 times
- chpsk8
- Has thanked: 27 times
- Been thanked: 70 times
We've used a 3" foam topper I got off amazon with good luck. Electric knife to shape it. Next one I'm going to mattress factory and getting exactly what I want.
- Has thanked: 57 times
- Been thanked: 968 times
- Has thanked: 254 times
- Been thanked: 1095 times
- amanphoto
- Bentone23
- Vessel Info: 1996 Carver 355 Aft Cabin
454 xls EFI - Location: Central California
- Has thanked: 39 times
- Been thanked: 5 times
- Contact:
Bentone23@sbcglobal.net
1996 355 Aft Cabin
Central California
Boating on the Delta and SF Bay
