Air Conditioning Pump/Sump Pump WTF
- vineyardgray
- Captain
- Has thanked: 125 times
- Been thanked: 32 times
- Contact:
I opened up the strainer to see if it needed cleaning but it seemed pretty good. Then I closed the strainer and turned the system back on - the pump sounded like sand was being poured down a pipe. This I recall having been told once is what cavitation sounds like and so I started looking for a way for air to get in. I looked suspiciously at the strainer lid.
These strainers are old cork gasket jobs and I'm sure they're in need of some new cork. Good job for the winter, but for now I gave a twist on the lid wingnut with some pliers and the cavitation sound improved some but not all. I cranked again and "snap" - the wingnut stripped the thread and I lost my ability to refrain from swearing.
Found a solution though:
Then I noticed the float switch for the bilge was floating but no pumping was going on. Looked like some crap™ was stuck in the pump so cleaned that out. Looked at the wiring and the connections were all taped together - so took that apart and found another mess. But look at this wire! Pink and brittle.
I had to cut a long way to get to good wire. This is factory wire and is not tinned. Bummer.
1988 Carver
3867 Santego
PCYC
- Has thanked: 547 times
- Been thanked: 1143 times
Re: Air Conditioning Pump/Sump Pump WTF
