Good news and bad news
- Cooler
- Has thanked: 66 times
- Been thanked: 371 times
Now the bad...my hydraulic steering fluid started leaking out of the helm. Checked fittings on other side, hoses, all check out good, so it is coming out of the helm pump as far as I can tell. The helm is the original, so probably needs replacement. Any suggestions on a helm brand? There are 3 hoses connected in back. Hope I can just swap out the helm without doing the whole kit. Thoughts? er
- Been thanked: 587 times
Re: Good news and bad news
- Has thanked: 432 times
- Been thanked: 1588 times
Have you determined where it's leaking from? Could be as simple as tightening a fitting or plug, or replacing a seal. Shaft seals are a common failure point. You can purchase a seal kit and reseal the unit. They're not that bad to work on.
- Cooler
https://www.google.com/url?sa=t&source= ... 4055565232
- RobGunn
- Vessel Info: 1990 Carver 3607 Aft Cabin
"FINALLY" - Location: St. Joe MI
- Been thanked: 21 times
- Has thanked: 59 times
- Been thanked: 970 times
1996 Boston Whaler Rage 15 - Location: Saint Joseph,Mi
- Has thanked: 50 times
- Been thanked: 399 times
A fairly easy job to complete.
Users browsing this forum: No registered users and 66 guests
