1990 3608 aft cabin freshwater pump location
- Take5
- Vessel Info: 1990 3608
1996 Boston Whaler Rage 15 - Location: Saint Joseph,Mi
- Has thanked: 50 times
- Been thanked: 401 times
Re: 1990 3608 aft cabin freshwater pump location
When connected to city water you should have city pressure.
Filter clogged?
Bad pressure reducer?
- Take5
- buster53
- Has thanked: 8 times
- Been thanked: 256 times
If not there, turnoff the dock water, turn on your water system and follow the sound of the pump.
Agree with others, sounds like a partially clogged filter
- Been thanked: 590 times
- Has thanked: 60 times
- Been thanked: 981 times
- Take5
- denpooch
- Has thanked: 85 times
- Been thanked: 86 times
This diagram seems to explain the system. I do not have an 'accumulator tank' in my system.
https://newcontent.westmarine.com/conte ... ater-4.jpg
Also check the individual faucets. There are usually screens in the aerators that could be getting clogged up not allowing flow. That's really the only common point to either the shore water or the on-board pump. Often the on-board pump runs at a higher pressure than the shore water so that might explain why you see a trickle when it's on.
Users browsing this forum: Google [Bot] and 29 guests
