Trim tabs, controller/pump drama
- Phrancus
- Has thanked: 16 times
- Been thanked: 122 times
- Contact:
My question; is it worth to replace the pump or should I install a different type of trim tabs control (no pump, manual position, different brand pump)
general question: how does the trim tab and the heckdrive position trimming work together?
We will seldomly be able to go so fast to get her into plane but when I'm at it (overhaul everything) anyway, I'd like to do the job well. Within reasonable cost.
Any tips welcome.
- Has thanked: 547 times
- Been thanked: 1143 times
Re: Trim tabs, controller/pump drama
Anyway long story, I just bought a complete refit kit from Bennett trim tabs ( fantastic after sales support ) to replace the old Insta trim, thereby using the existing wiring, switch etc.....you get the pump, plastic hose/fittings and rams that go to the exiting trim planes.....No external hoses..... Easy refit....check out their site....there are electric options as well from ???? the name escapes me right now.
- Beufort
- Vessel Info: 86’ montego 26.
- Has thanked: 4 times
- Been thanked: 5 times
- Phrancus
- Contact:
A former owner had a problem with them, one of the tabs was 'off' and he only came up with cutting the hydraulic hose..... perhaps after molesting the unit itself as the bottom part is missing.
Anyway, first up is the port drive; cooling problems on that engine, probably growth in the inlet. I am going to add a bypass water pickup near between the drive and the engine. For our use, there's not much benefit in have the water coming through the vulnerable holes in the drive. In fact, this boat is not coming out of the water all season so growth is a given. Better to have an extra pickup which is also easier to clean regularly while in the water.
- Has thanked: 431 times
- Been thanked: 1586 times
- PossiblyPaul
- Vessel Info: Hornbill III
1988 Carver 2827 Voyager,Volvo Penta TAMD31 engines.
Ardglass Marina, County Down - Location: Ardglass, County Down, Northern Ireland
- Has thanked: 48 times
I'm presently hoping that https://www.trimtabsdirect.com will be able to replace for me - and they'll be bolted to the hull with A4 steel and a lot of Sikaflex! The 4-button controls are a perished pain, too; will be replaced with DPDT switches.
- Has thanked: 313 times
- Been thanked: 581 times
What drives do you have? There is a good chance you impellers are inside the drives. You cant just bypass them.
- Phrancus
- Contact:
The impellers are at the front of each engine, and for winterizing one is supposed to detach the tube from the drive and dip in an a bucket of coolant.
Sorry to hear about your trimtabs adventures, especially the water coming in must have been a pretty nasty surprise!
Users browsing this forum: Google Adsense [Bot] and 74 guests
