Stove
- Chona
- Vessel Info: 1988 Carver 3607
- Has thanked: 2 times
Stove
- buster53
- Has thanked: 8 times
- Been thanked: 253 times
Re: Stove
Just making sure…you do realize you will have to stay with a 120 volt stove as opposed to your typical home unit which is 240 volts.
- Has thanked: 59 times
- Been thanked: 969 times
Re: Stove
You might poke around in the Project forum for threads there. There was one member who replaced his stove with a microwave and then built an enclose to add a toaster/convection oven. I think I would have gone that route if I ever had to replace the Princess we had.
Edit: I poked around a little bit to see if I could find that thread, but didn't (I didn't look that long though)
But I did find this one with a similar issue that you might consider:
viewtopic.php?f=13&t=5946&p=47277&hilit=toaster#p47277
- vineyardgray
- Captain
- Has thanked: 125 times
- Been thanked: 32 times
- Contact:
Re: Stove
https://www.marineoutfitters.ca/mobile/?page=shop&category=11377|10360&product=64584857
1988 Carver
3867 Santego
PCYC
Re: Stove
vineyardgray wrote:Source of the post I have been looking for a replacement stove for my 1988 as well. Mine came with a Princess 3 burner electric. I have been told, but haven't confirmed, that the Force 10 three burner electric can be sold with a trim kit to fit the exact opening of the Princess.
That's a nice unit, and I like the ceramic top. It also has the pot holder, which can be necessary if you're not at the dock.
However, I did see this in the spec: " Required Circuit Breaker: 40 Amp"
If your 3 burner Princess was like mine, it was on a 15 or 20 Amp circuit. When the over was being used, you could only use one of the top burners. You would need a circuit upgrade (new wiring too) for that new oven combo, but you'd still be limited by a 30A shore power cord.
- vineyardgray
- Captain
- Contact:
Re: Stove
The other limitations are not really too bad in my case - I have a 50a service at my slip, and when at other marinas, my inverter will make up the additional amperage for periodic loads over 30a. This is actually a perfect example of how the system works.
1988 Carver
3867 Santego
PCYC
- buster53
Re: Stove
vineyardgray wrote:You make a good point. Wiring and breaker would need upgrading.
You might have 50 amp service at your dock, but your boat is only wired for 30 amp. Try to pull more than 30 and you start popping breakers. I’m guessing your boat has 2, 30 amp connections. One for AC service and the other, all other house loads. I’m also guessing your oven is on a 20 amp breaker. My stove/oven, you can only use one or the other, not both. Not even one burner if the oven is on.
- vineyardgray
- Captain
- Contact:
Re: Stove
But if I am on a 30a pedestal for the house loads, and I have a demand over 30a, my inverter will draw power from the battery bank to supplement. Assuming the wiring and breakers are sufficiently sized, of course. Dang fancy tech.
1988 Carver
3867 Santego
PCYC
- mjmason1
- Vessel Info: 1999 Carver Voyager 530
- Been thanked: 19 times
Re: Stove
Users browsing this forum: paulr and 53 guests
