Regarding Pink Stuff
- Phrancus
- Has thanked: 16 times
- Been thanked: 122 times
- Contact:
Re: Regarding Pink Stuff
- Has thanked: 59 times
- Been thanked: 969 times
Phrancus wrote:Source of the post Which raises the question why on earth drain plugs are a few mm while they could easily be made much larger so they drain in a firehose fashion kind of way. I mean there is no difference to the engine and its functioning wether a drain is 2 inches or 1/2 inch wide. A large opening when closed it is closed and when open it drops everything inside in a few seconds.
Funny.. I was thinking the same thing. Maybe not going as large as 2" (because that would probably be expensive) but maybe a size or two larger than what I typically see, which I think is 3/8 or 1/2".
- Has thanked: 432 times
- Been thanked: 1587 times
Users browsing this forum: No registered users and 57 guests
