Replacing the port fuel tank on a Carver 42 ACMY
Topic author - Scurvy Dog
- Vessel Info: 1991 42' Aft Cabin Sun Deck
1996 Boston Whaler Rage 15 - Location: Saint Joseph,Mi
- Has thanked: 50 times
- Been thanked: 399 times
Re: Replacing the port fuel tank on a Carver 42 ACMY
When we had our 4207, I took the cabinet face and dividers apart to install a large TV in the cabinet, a home stereo, along with Klipsch speakers. It's not that hard to disassemble, and I would think much easier than taking the engine apart or out. But I would do alot of checking to make sure the tank would come out through the hole you make under that cabinet once removed. Also check what's underneath all of that. You'll want to check the relationship to the tank and the main cabin a/c unit, though I think the genset is right below the a/c unit.
Also, if I recall, the floor structure has a removable hatch above each engine, and an aluminum superstructure holding up the floor and the hatch. I believe you'd have to remove some or all of the structure one that side of the boat. Mine had wireways attached to that structure which could get fun.
I've heard of shops cutting the sides out of older Hatteras boats to replace the stinky Detroits with more modern cats, mans, etc. But I also believe once the engine is back in, the entire inside of the boat is accessible to do the inside fiberglass work. I guarantee you, you will not have the ability to get to the backside of the reinstalled plug to support it properly and re-fiberglass it in. I just don't think you could do it "right" on a 4207 - no room.
EDIT: Just had another thought - could you cut a portion of the tank open and install a bladder? That would probably be cheapest. And it should last a very very long time.
- AaHubb
- Vessel Info: '99 404 CPMY
- Has thanked: 15 times
- Been thanked: 60 times
SeaDragon
Remove the carpet, pull the hatch, set up an a-frame over the engine, lift it up, put the hatch back down, some heavy wood, and set the engine down to take some weight off the frame.
Then disconnect the tank and pull it out the stairway.
- AaHubb
SeaDragon
If you needed to do an R&R on the engine, that's what you would do.
- CYO Admin
- CYO Administrator
- Has thanked: 269 times
- Been thanked: 26 times
The hardest part of the whole process was removing the galley. I'm not saying it was easy, but it's very doable with the right equipment.
Users browsing this forum: No registered users and 37 guests
