Fuel tank capacity - 1998 355
Topic author
Boathooked
Postby Boathooked » April 1st, 2014, 11:12 am
I am trying to get a definitive answer on fuel tank capacity for my 1998 Carver 355.
In my research I have come across the total gallons as 318 (though sometimes as 320) gallons. I do have the aft aux tank which I see references to being 120 gallons, and then the port/stbd tanks at 100 gallons (of course this equals 320 gallons, not 318) though sometimes the port/stbd tanks are listed at 99 gallons (which would give 318 gallons).
I do have the owners manual but it is not clear on exactly what is what, thus my question. Any help would be appreciated!
Ramsport47
Been thanked: 59 times
Re: Fuel tank capacity - 1998 355
Postby Ramsport47 » April 2nd, 2014, 6:30 am
I believe the official tank capacities are 100 for each side tank, and 118 for the aux tank. That's what we have found on a boat that we had to replace the tanks in.
Kenny
T-Merc 350 Mag MPI (300hp)
Topic author
Boathooked
Postby Boathooked » April 2nd, 2014, 12:28 pm
Thanks Ramsport47.
glazingguru
Vessel Info: 1995 Carver 355 Aft Cabin
Postby glazingguru » May 6th, 2014, 11:43 am
I would be interested if you learn anything more on this.
The way I understood it when I bought my boat was that the two side tanks were each 125 gallons and the rear (aux) tank is 68 gallons. I believe this to be true, although I have never run the side tanks out and the aux tank has always been empty since before I bought it.
MissWhit's
Location: Eisenhower yacht Club, Lake Texoma, Sherman TX
Been thanked: 4 times
Postby MissWhit's » May 7th, 2014, 3:37 pm
If you really want to know the tank volume on any boat simply measure the tank width x height x depth to come up with total volume and divide by the volume one gallon of water takes up. I bet the volume of a gallon of water can be found on the internet.
MissWhit's
Lake Texoma, Denison TX
Port: EYC Marina
2001 406 twin 380HP 454 MPI
glazingguru
Postby glazingguru » May 8th, 2014, 5:30 pm
yes, it's 231, although you have to account for rounded corners or odd shapes, that only works on square and rectangle shapes
