Tranny Chatter 1000-1400 RPM
- Sadey
- Vessel Info: Former owner of a 2003 Carver 356 with 8.1 Mercs
Agradecida
Current owner 1989 60’ Hatteras MY with 8v92 Detroit’s
Benedetto - Location: Racine Wisconsin/Ft. Lauderdale
- Has thanked: 4 times
- Been thanked: 29 times
Dave & Trina
- Sadey
Agradecida
Re: Tranny Chatter 1000-1400 RPM
Dave & Trina
- Has thanked: 313 times
- Been thanked: 581 times
Good luck.
- Has thanked: 431 times
- Been thanked: 1586 times
The chatter could be a number of things from the tranny to the engine. Tom is correct re the damper plate, could also be an engine runnability issue causing the tranny to react that way. Are you sure it's coming from the tranny? A broken off damper in a muffler can cause a chatter as well but because everything is in the same area, it may sound like it's coming from somewhere else unless it's obvious or you get up close and listen through a devise like a screw driver.
Keep us posted.
- Sadey
Agradecida
Thank you all again for the info!!
Dave & Trina
Hope it all works out. Keep us posted.
- Sadey
Agradecida
Dave & Trina
- Has thanked: 56 times
- Been thanked: 965 times
- Sadey
Agradecida
Dave & Trina
Users browsing this forum: Google [Bot] and 33 guests
