What's under your distributor cap?
- mjk1040
- Been thanked: 236 times
- Has thanked: 254 times
- Been thanked: 1095 times
Re: What's under your distributor cap?
- Has thanked: 57 times
- Been thanked: 968 times
If you see ANY signs of actual rust in there, then DEFINITELY make sure your mechanical advance is working, if the distributor is equipped with it. I have an older classic car and pulled the cap once and I was SHOCKED to see that the advance was rusted up and one of the springs broke. That car RARELY sees any rain and NEVER sees winter. Took several hours to clean the distributor up and get it running correct again. A periodic spray with some lube would have avoided that if I had any inkling that there was an issue going on!
- mjk1040
- Has thanked: 547 times
- Been thanked: 1143 times
People will say you don't need it but if it was there you do.
- SplashyLady
- Captain
- Has thanked: 20 times
- Been thanked: 87 times
Here's an example of a spring set: https://www.summitracing.com/parts/mrg- ... refilter=1
Lake Norman, NC
Carver 3227 - "Splashy Lady"
- mjk1040
My merc uses a gasket.
- mjk1040
