Holly Carb issue
Dpoelstra
Topic author - Scurvy Dog
Holly Carb issue
I thought maybe needle and seat, but it turned out to be a stuck open power valve. It was dumping fuel all the time.
I bought a kit and tried my first overhaul, which scared me. I soaked everything overnight, cleaned, checked and double checked everything. Now she runs perfect. I just need to change the plugs.
"Brown Eyed Girl"
1981 Carver 3007 30ft. Aft Cabin
Huntington Harbour, Ca
"But why's the rum gone....?"
- Been thanked: 490 times
Re: Holly Carb issue
Good Job!
EscapeArtist
- Vessel Info: 1981 Carver 3007, twin Crusader 270's
Craig
A holley has 4 venturi all the same size. A quadrajet has 2 small primaries and 2 huge secondaries.
And you YouTube does have videos.
EscapeArtist
The best thing to do is soak all the disassembled parts in hydraseal. Our buy two cans of gum out and spray every hole for at least a few seconds. At least as long as it takes to come out the other end of the hole.
Do NOT bend any linkages.
You will be fine.
