1981 28' Mariner trans?
28Carver
Vessel Info: 28' Carver Mariner
Postby 28Carver » December 7th, 2020, 7:46 am
Any guess as to what transmission would be in a 1981 28' Mariner with twin inboard 305s? I cant make out anything on the tags.
Re: 1981 28' Mariner trans?
Postby bud37 » December 7th, 2020, 10:02 am
Welcome to the forum....my guess if original.....Velvet drive....are the engines painted blue?
If you have a pic of the trans someone may be able to ID the specific model.
28Carver
Postby 28Carver » December 7th, 2020, 10:58 am
bud37 wrote:Source of the post Welcome to the forum....my guess if original.....Velvet drive....are the engines painted blue?
Pretty sure these are original equipment. The engines are painted blue. Can barely make out the 220 on valve cover. I'm going to run out to the marina today if I get a chance and do some more digging for name plates and snap some pictures.
throwback2
Vessel Info: 1987 Carver 28 Voyager,twin small blocks,1991 Shamrock,350 Chevy now.
and a few other water toys
Has thanked: 8 times
Been thanked: 23 times
Postby throwback2 » December 8th, 2020, 10:39 am
Probably Borg Warner velvet drives 1.5 reduction V drives based on 220 hp.Crusader conversions.
28Carver
Postby 28Carver » December 9th, 2020, 7:35 am
Velvet Drive 1:1 ratio 71c is the answer.
Now to ID the V-Drives a little more specifically. I know they are Walters...but havent seen the tag on them yet. A little internet search tells me they are on the back side of the unit so reading it may be a challenge.
Postby bud37 » December 9th, 2020, 7:59 am
A bright light and a mirror may come in handy. Is there a short shaft going from the trans to the v drive gear case ?
The color in that pic does not seem to be the blue I was thinking.
28Carver
Postby 28Carver » December 9th, 2020, 10:15 am
Nope. No shaft. Here is a better pic of the rust and spaghetti under the hatch.
This boat has been sitting in the salt water with little to no use for over 4yrs I was told. We brought a bunch of tools, cooler, sleeping bags and a chase boat to rescue it and bring it back to the fresh water of the Sac Delta. Starboard motor wasnt running properly, later determined to be severely retarded ign timing. We have it running pretty well on both motors now.
Going to make a great Delta/Bay beater.
Has thanked: 474 times
Postby Viper » December 9th, 2020, 11:21 pm
Ya that's a Walter without a jackshaft.
