Crusader 6.0 T-stat question
Delorean6855
Vessel Info: 2004 Mariner Three Sixty, Crusader 6.0s w/225 hours, Koehler 7_3e genset
Been thanked: 5 times
Postby Delorean6855 » December 20th, 2020, 12:39 am
Hi, have 2004 Crusader 6.0s... hopefully a simple question...to change the t-stat on the heat exchanger, do you need to drain off any of the coolant? I can’t tell if the housing is below or above the degas bottle fluid level... thanks!
Helmsman
Has thanked: 73 times
Been thanked: 42 times
Re: Crusader 6.0 T-stat question
Postby Helmsman » December 22nd, 2020, 8:24 am
Delorean6855 wrote:Source of the post Hi, have 2004 Crusader 6.0s... hopefully a simple question...to change the t-stat on the heat exchanger, do you need to drain off any of the coolant? I can’t tell if the housing is below or above the degas bottle fluid level... thanks!
On my 6.0 heat exchanger, I lowered the level of antifreeze a little. I used a pump I use for oil and transmission fluid changes. Changed out the heat exchanger, Thermostat and all hoses on the starboard engine last spring. I sold my boat, but have a partial set of new hoses for the 6.0 and I think I have a new t-stat available which I was going to put on the port engine. Was planning to list them on EBay after the first of the year but will entertain selling them for a decent price here, if you can use them. PM me if you or anyone else is interested.
denpooch
Vessel Info: 2005 360 Mariner
Crusader 6.0 Captains Choice
Has thanked: 85 times
Been thanked: 89 times
Postby denpooch » January 30th, 2021, 9:17 pm
Delorean6855 check out page 30 - figure 12.
https://www.marinepartsexpress.com/Crus ... 4-2005.pdf
