Anybody know what this is?
- Washopay
- Vessel Info: 1990 3807 Aft twin 7.4 Mercruisers
1984 3207 twin 270 Crusdaers - Location: Barrie, ON
- Has thanked: 23 times
- Been thanked: 5 times
I'm having a problem with my Onan Genny. I believe I've isolated it down to a fuel issue. Does any body know what this silver can on the right is? It is past the filter on the fuel line leading to the genny.
- Has thanked: 547 times
- Been thanked: 1142 times
Re: Anybody know what this is?
- Has thanked: 431 times
- Been thanked: 1586 times
- Washopay
Viper wrote:Yes, in-line fuel filter. Not needed there though. In fact it may cause problems. What symptoms are you experiencing?
Beginning of the season, it sputtered to halt after 1/2 hour run time. Then 20 minutes. I'm down to about 5 now. I've put a thermal gun to it and it is not overheating (I think if it was a sensor grounding it would shut right off not sputter to a stop). I've replaced the sensor to be sure, and the oil pressure sensor (Level is good). Thermostat, strainer, impeller, all good.
It starts fine, runs fine then suddenly starts to sputter and fart and then just dies. I found that a new marina I have been buying gas from is providing fuel with 10% ethanol (arrrgh). I'm thinking this might be the source of my problem. Sooooo.... I'm going to replace the filters next and try. Then (I suppose), I have to check the tanks to see if there is water.
I'm wide open to other ideas! Thanks Viper and Bud37
- Low Flyer
- Vessel Info: 1998 Carver 355 MY
Mercruiser Bluewater 454's - Location: Allatoona Marina Resort, Lake Allatoona, GA
- Has thanked: 2 times
- Been thanked: 7 times
You may just have a partially clogged fuel filter (inline filter that shouldn't be there) that is restricting the fuel flow.
A fuel stabilizer should be part of your re-fueling regime to help inhibit ethanol and water problems.
1998 355 Aft Cabin
- Washopay
- SplashyLady
- Captain
- Has thanked: 20 times
- Been thanked: 87 times
Lake Norman, NC
Carver 3227 - "Splashy Lady"
