Maintenance on Walter V-Drives
- Seif911
- Captain
- Vessel Info: 1977 Carver Mariner 33'
- Been thanked: 3 times
So my last trip I had a low oil light go off for the Walter V-Drives. What oil do I put into the drives? Do I just pour it into the dip stick hole?
Steve
- CYO Admin
- CYO Administrator
- Has thanked: 269 times
- Been thanked: 26 times
Re: Maintenance on Walter V-Drives
It's my understanding that all Walter's take SAE 30 oil but it would be worth pulling the dipstick to see what's in there now (oil or ATF).
- CYO Admin
- CYO Administrator
As soon as you start the engine(s) you should see the warning light glowing. The light will keep glowing when you shift into gear and will stay on until you reach anywhere between 800 and 1600 r.p.m. at which point the oil pump inside the V drive will create enough oil pressure to cause the light to go out. If it doesn't go out by 1600 RPM, try replacing the pressure switch with a standard oil pressure switch from any chain auto parts store (take the old one with you to make sure you get one with the right size threaded mounting stud). If that still doesn't work, it is time to have the V drive rebuilt, which costs about $250 and involves replacing the oil pump and all the seals.
1996 Boston Whaler Rage 15 - Location: Saint Joseph,Mi
- Has thanked: 50 times
- Been thanked: 396 times
- Seif911
- Captain
Steve
