Engine removal from 1991 38' Carver Aft Cabin
- Has thanked: 314 times
- Been thanked: 583 times
Re: Engine removal from 1991 38' Carver Aft Cabin
Next, as mentioned above, you may be able to salvage these and get several more years from them. Being raw water cooled, you have a good chance that the manifolds and or risers are the source of water. If you didn't run them long with the water in the oil, you may be able to change the bad manifolds etc. Swap the oil a couple times and keep going.
These are tough motors, if the crank bearings weren't damaged and water didn't get into the cylinders (hydro lock) you could be good for several hundred more hours....
- tim.layden
- Vessel Info: 1988 Carver 3807 Aft Cabin
- Has thanked: 59 times
- Been thanked: 969 times
tim.layden wrote:Source of the post I just changed out an engine (mercruiser 7.4) in my 88 3807, stripped the heads off and come alonged it up a ramp thru the salon doors onto the aft deck, then used same ramp to move it off aft deck onto dock. Reinstall was the reverse.
Wow. That would be an interesting thread... WITH PICTURES!
I've been wondering what I'd do if I had to get the 7.4's out of my 3607. I pulled the tranny and reduction gear by myself with a jig rigged up to handle most of the load, but an entire block is much different!
- dcrahn
- Vessel Info: 1984 Carver 2687 Monterey
- Been thanked: 4 times
- Has thanked: 432 times
- Been thanked: 1588 times
- Vessel Info: 1986 32' Aft
