Walter V Drive Systems Gearbox Q
390Express
Has thanked: 141 times
Been thanked: 15 times
Re: Walter V Drive Systems Gearbox Q
Postby 390Express » May 22nd, 2018, 10:22 am
Viper wrote:Source of the post
390Express wrote:Source of the post ....I have the impeller belt, and water pump belt off of it. I planned to start it and run it for 3-5 min. at a time, a couple times, before I launch.....
Be careful here, it doesn't take long for the inside walls of your exhaust hoses to be destroyed when there's no water cooling them.
Thanks Viper, I keep it closer to 2-3 minutes of run time, with a careful hand on the glass portion of the exh system to make sure it's not getting too hot.
Has thanked: 431 times
Been thanked: 1586 times
Postby Viper » May 22nd, 2018, 1:28 pm
Why not run it with water?? Then you can run it as long as you want.
390Express
Postby 390Express » May 24th, 2018, 3:10 pm
Viper wrote:Source of the post Why not run it with water?? Then you can run it as long as you want.
No damn water or electricity at its current location. Marina won't let me launch it until I know it runs. It has to at least power itself to the dock, then I can really start working on it. I have heavy equipment to pull anything that needs to be pulled at the dock. P.I.T.A.!
Has thanked: 547 times
Been thanked: 1143 times
Postby bud37 » May 24th, 2018, 8:44 pm
Curious when you took that pan plug out....what all did you get out of the pan ?
The above is strictly my opinion always based on years of doing...remember to support local business , it pays back.
390Express
Postby 390Express » May 27th, 2018, 1:07 pm
bud37 wrote:Source of the post Curious when you took that pan plug out....what all did you get out of the pan ?
I drained it completely before pulling to pan plug. I got about another 2/3 - 3/4 of a quart out of the pan with the plug out. It really wasn't difficult at all. I kind of wish the factory would swap the dipstick from the middle to the outside, it would be a lot easier if the plug was located in the middle of the boat.
Because of the numerous ongoing projects this year, I likely won't mess with anything to do with oil drainage, but next year I will likely add a drain system. I'll probably add a T- at the elbow that has the dipstick, so I can do everything from the middle of the boat. A "T" fitting, shutoff valve, and some 3/8 brass piping, with a cap when not in use should make the job much easier, and drain more oil out of the system.
Postby bud37 » May 27th, 2018, 6:59 pm
Heh there....just an FYI.....you may know but there is nothing Trojan about your boat cept the name, it is all Carver as far as I know....posted it here cause didn't want to misdirect the other thread......so it was all oil out the bottom of the pan , good stuff........
Postby bud37 » May 27th, 2018, 8:01 pm
Here is something may help .its a 95 but, check it out.......
https://carveryachts.blob.core.windows. ... _95_v1.pdf
390Express
Postby 390Express » May 30th, 2018, 10:00 am
bud37 wrote:Source of the post Heh there....just an FYI.....you may know but there is nothing Trojan about your boat cept the name, it is all Carver as far as I know....posted it here cause didn't want to misdirect the other thread......so it was all oil out the bottom of the pan , good stuff........
Ha, yup, I'm aware. That's why I'm here, on the Carver forum. :drunk:
I only post the "Trojan" info, so people know the model I have. I believe Carver also made an Express during the same time frame. 3566 or something of the like?
