1994 Merc 7.4 Carb impeller Kit
- tonyiiiafl
- Has thanked: 593 times
- Been thanked: 175 times
- Has thanked: 432 times
- Been thanked: 1599 times
Re: 1994 Merc 7.4 Carb impeller Kit
Don't forget that the oil in that pump assembly needs to be replaced periodically. Make it part of your regular maintenance by replacing it every time you replace the impeller.
- tonyiiiafl
EVERY year I remove the fuel pump and replace the gear lube in the boss part of the pump. I had a failure on one and saw it was all washed out and like water. So now it is part of the preseason maintenance. EVERYONE should heed your advice on this!
I believe I have pump 46-807151A8. Would I be looking for kit 46-807151A14?
Check the wear plate, if it's grooved get a new one or you can flip those over. Also check the bottom of the inside of the pump housing, that will indicate if you need a new housing or not.
- tonyiiiafl
- mjk1040
- Been thanked: 237 times
- Has thanked: 550 times
- Been thanked: 1151 times
tonyiiiafl wrote:Source of the post I just am leery of putting the pump in with a 2 year old impeller that probably has a "set" in it.
I agree, what I have done was take the new impeller out to be on the safe side and replace with a new one then keep that one as a spare, you can tell if it will be ok later if the "set" straightens itself out.
- mjk1040
