Alternator Replacement
- mvpacificrose
- Vessel Info: 1988 Carver 3807
- Has thanked: 1 time
The issue I'm having is what to do with the yellow wire coming from the boat to the alternator? The previous alternator had a clip plug, but as the name implies...the 1 wire alternator only has the output terminal.
Where do I connect the yellow wire coming from the boat?
1988 Carver 3807, 454 Crusader's
Thanks,
-Dale
- KandJ72
- Vessel Info: '76 Carver Mariner 3395
Twin 351W Vdrives
Refit in process - Location: Central NY
- Has thanked: 20 times
- Been thanked: 3 times
Re: Alternator Replacement
chances are that's an Energize/Field wire that was needed by the original Alt. You should be able to just cap and secure it with the new Alt because they are self energizing and regulated.
