DEXRON II replacement?
- tonyiiiafl
- Has thanked: 589 times
- Been thanked: 175 times
- Has thanked: 314 times
- Been thanked: 585 times
Re: DEXRON II replacement?
Even in 70's and 80's cars.
- Phrancus
- Has thanked: 16 times
- Been thanked: 122 times
- Contact:
for example:
Dexron IID
MB 236.6/236.7
Ford Mercon/M2C138-CJ/166-H
MAN 339 Typ Z1/V1
Allison C4
Cat TO-2
Voith 55.6335 (G607)
ZF TE-ML 09/11A/14A
So I understand that Dexron is a high level designation and each manufacturer gives it its own twist and gives it a codename. If there is physically something different in those variations may be but that's a complex matter and I take it as the same in normal conditions.
Special circumstances may demand that specific manufacturers version, such as service under warranty (so more a legal issue) or very hot/cold/heavy use/extremely light use etc.
- Has thanked: 550 times
- Been thanked: 1146 times
Call or Email Hurth for a list of their compatible oils for that year trans. Someone may have used another hydraulic fluid for a reason, who knows. Simply Dexron under many different numbers is basically a GM branded fluid that has changed for car trans needs and EPA reasons over the years.
Good luck with this new adventure.
- tonyiiiafl
- tonyiiiafl
