1989 Carver Montego w/Volvo Penta AQ271c
- jrides55
- Vessel Info: 1989 Carver Montego Mid-Cabin
- Has thanked: 2 times
Does anyone know what this black, vertical tube does? Is it possible that this tube could be plugged? I can't seem to find anything to help me identify this. Thanks!
(Not a Carver) 1972 Glastron V-176 Swinger
- Has thanked: 59 times
- Been thanked: 970 times
Re: 1989 Carver Montego w/Volvo Penta AQ271c
Yes, it could be plugged. You could remove the raw water hoses from each end and spray water though it backwards, or use a wet/dry vac on the "input" side to see what you might be able to suck out.
I'm guessing you're having some kind of overheating issue that you're trying to resolve? What have you done so far to investigate the issue?
- Has thanked: 432 times
- Been thanked: 1588 times
