1987 Carver 3697 filler neck and overheat
- carver3697'87
- Vessel Info: 1987 Carver 3697 Mariner
- Has thanked: 1 time
- Has thanked: 432 times
- Been thanked: 1588 times
Re: 1987 Carver 3697 filler neck and overheat
- Has thanked: 59 times
- Been thanked: 969 times
If you think there was enough pressure to cause physical damage, then you should test and/or replace the cap. They should release any pressure that gets over about 15 PSI.
When did the actual overheat happen? Was it up at cruise or after a cruise? How long do you think it was actually HOT before it overheated? Did you get any alarms?
Users browsing this forum: g36 and 18 guests
