5.7 water pump
- Dad Joke
- Vessel Info: None yet
- Been thanked: 3 times
5.7 water pump
water pumps from Crusader or will automotive application suffice?
- Cooler
- Has thanked: 66 times
- Been thanked: 371 times
Re: 5.7 water pump
- Has thanked: 432 times
- Been thanked: 1588 times
Re: 5.7 water pump
- Has thanked: 550 times
- Been thanked: 1145 times
Re: 5.7 water pump
Dad Joke wrote:Source of the post I have a 3207 with two 5.7L inboards, using fresh water (closed circuit) cooling. Do I need engine
If you are using an automotive pump for closed cooling, be sure to get the one that fits right. I believe the distance from the block surface to the pulley mounting point changed over the years......marine uses the older shorter one If I remember. Just be aware to check fit first as there are some differences to be aware of.
- Has thanked: 314 times
- Been thanked: 584 times
Re: 5.7 water pump
