Change Gear Oil in IPS 500 Drive Unit
- Rocketman
- Vessel Info: 2009 44 Sojourn w/ Volvo Diesel D6-500 engines and IPS drive system.
- Been thanked: 17 times
It was done while the boat was out for hauling and bottom paint the last time so that was easy enough out of the water.
The manual states that you can change in the water with a pump and adapter fitting.
Question is - what adapter fitting and pump do I need to purchase. I can't find anything on the web or in the manual that has a part number or any details.
I hate to pay to pull the boat along with the 30 mile run each way to the lift.
Would like to be able to do it myself as I do all my other maintenance.
Thanks,
Tony
- Has thanked: 57 times
- Been thanked: 968 times
Re: Change Gear Oil in IPS 500 Drive Unit
However, when perusing the Maintenance manual for the ZEUS, I did also see where that system could be done in the water. There was a port right above the pod and below the transmission that you could remove and connect the adapter there. I am sure I could have used that same pump I made if we had to use this port. The information was in their Operations and Maintenance Manual, which I was able do download free. The actual Service Manual you have to pay for, but if I owned one of these POD systems, I would spring for the $200 and for sure have one.
Here is the pump I made. next to the stock "outboard" pump:
- Rocketman
That is the adapter that I cannot seem to find anywhere.
Found the adapter.
Volvo part number - 990038
However, I am confused on the amount of gear oil I will need.
The manual states 7.9 Gal / 30 Liters.
When the marina did it while the boat was out of the water in Jan 2021 they charged me for 8 gallons to do both drives.
Did I get lucky and only got charged for 1/2 the gear oil?
Anyone have an idea?
- Has thanked: 431 times
- Been thanked: 1586 times
- Rocketman
Serial Numbers
3194008125
3194008126
- Rocketman
I really don't want to pull the boat for just a POD gear oil change which is all it needs. I have inspected the anodes and everything else in the water by diving.
Will do the pull out and drain/fill next time.
- Rocketman
Just FYI.
