Diesel Fuel Filters Replacement Frequency
- Has thanked: 257 times
- Been thanked: 1100 times
I should mention the secondary filter was the original when I purchased the boat with 1000hrs on the engines. They do have electronic water sensing built into them which will alert me if there is any water in them which has never occurred. I have been replacing those every other year since I got the boat, overkill?
- Has thanked: 59 times
- Been thanked: 976 times
Re: Diesel Fuel Filters Replacement Frequency
The best longevity would be running a pair in parallel and only switching over when the gauges start indicating restriction. Then you get the absolute longest life out of the filter, whether that's measured in hours, tens of hours, hundreds of hours, or thousands of hours. It also gives you a very quick method of overcoming a clogged filter situation and get back running in seconds rather than hours.
- Has thanked: 550 times
- Been thanked: 1150 times
Of course that will require quality gauges with the appropriate scales for your engines.
Now that said, good gauges and redundant filter system may buy a lot of filters..... ....then again, it may save you a lot on filters over time......
- Has thanked: 432 times
- Been thanked: 1594 times
Hans, when was the last time you checked your compressor oil level?
D6-370I-B HS 2006011117.
D6-370I-B HS 2006011246
Viper wrote:Source of the post Certainly keep an eye on gauges if applicable but the OEM recommendation is every 200 hours or at least once a year which ever comes first.
I believe the recommendation on the primary is 30 micron however I have been using 10 micron without issue as they always seem to be clean. I do not have gauges on my Racor setup. Here is the filter I use. https://www.dieselfiltersonline.com/par ... tm-or.html
I always carry spare fuel filters on board in case as I was almost stranded on a previous boat due to contamination.
Users browsing this forum: No registered users and 7 guests
