Cummins 450C No Start (Data Link Inactive)
trwestman
Vessel Info: 2002 Carver 506
Configured as a Soft-Top Bridge with Glass Aft-Deck
Cummins 450C (480hp) ~725 hours
Has thanked: 16 times
Been thanked: 7 times
Postby trwestman » October 13th, 2025, 9:35 am
Tried to start my Starboard engine. Key On there were no lights on the display panel. Specifically I look for “Wait to Start”. Digital display turns on after system checks and says “all systems ok” even though no data is on the screen, then changes to “Data Link Inactive. The analog gauges for voltage indicate 13.5 volts and Fuel is 3/4. Oil and Temp gauges are constantly moving. Engine will crank strong but not start.
I’m Leaning toward a broken wire or dirty connector at this point but not sure where to start. Any thoughts out there?
Tom
2002 506
KuyaJunGarage
Vessel Info: 2000 Carver 506
Re: Cummins 450C No Start (Data Link Inactive)
Postby KuyaJunGarage » October 13th, 2025, 1:35 pm
Check the solenoid? Jump to 3:50 on this youtube link (good explanation)
I have the same boat 2000 506
trwestman
Postby trwestman » October 13th, 2025, 2:00 pm
Thanks for that. I first need to check power at the ecm. Not sure how to do this. I have no signal output from the ecm. I wonder if the red fuse buttons might have something to do with this. The video references them when diagnosing.
Tom
2002 506
KuyaJunGarage
Postby KuyaJunGarage » October 14th, 2025, 8:17 am
No problem, let me know what you find out. good luck trwestman
trwestman
Postby trwestman » October 14th, 2025, 5:43 pm
I was able to check the fuel shut off solenoid. There was no power in or out. I was also able to get a wiring diagram from Cummins and check pin voltages. There are two circuits which are supposed to be 12V unswitched from the battery. Both were 0. In the diagram there are 10 amp fuses in both of those circuits. Can’t find them. Anyone have any ideas?
Tom
2002 506
Postby Viper » October 14th, 2025, 6:21 pm
If you have an automatic marine engine shutdown system installed, they're known to cause starting issues when they fail or have poor connections. These are common systems on diesel applications so if you have this, check it before replacing a bunch of engine parts. Fireboy/Xintex is one brand but there are others. Looks something like this and the box is usually under/behind the helm...
KuyaJunGarage
Postby KuyaJunGarage » October 15th, 2025, 8:37 am
trwestman - did you check the voltage on the port solenoid engine? Im guessing they have 12volt.
Under the steering wheel there is a vent that you can remove, check the igniton cylinder
Users browsing this forum: No registered users and 86 guests
