1986 3297 Mariner Windows
Topic author
Grussell
Vessel Info: 1986 Mariner Model 3297
Postby Grussell » February 15th, 2017, 9:33 pm
My Windows leak. Has anyone ever replaced and upgraded thes RV type sliding windows with custom designed Windows. I've been told rebuilding/restoring the original Windows will not entirely solve the problem. They are all currently caulked sufficiently to stop the leaking but are non-functional in this state. Any direction/suggestions are appreciated. I fully expect to spend what it takes to resolve this problem.
Been thanked: 248 times
Re: 1986 3297 Mariner Windows
Postby mjk1040 » February 16th, 2017, 4:25 am
Owned this model, I do not believe you will find a replacement, Taylor made a lot of these for Carver, you may check with them. My thought is you may have to remove the entire window, maybe a glass install shop could re-bed the sliders for you and you can re-bed the windows back onto the boat. Mike
Bob Miller
Vessel Info: 1989 carver 3297 mariner
Postby Bob Miller » February 16th, 2017, 8:52 am
I have a 1989 3297 mariner......... I just used a tooth brush after I took the windows out ( their are some small rubber trim pieces in the tract of the windows in the top that need to be removed ) and be sure to clean the small slots out at the bottom of the windows that let rain water escape if you do not clean them the water will dam up and move inside the boat instead of dripping outside and down the sides of the boat
Topic author
Grussell
Postby Grussell » February 16th, 2017, 2:48 pm
Thanks for the feedback. Much appreciated!
redgin6
Vessel Info: 1989 Carver 3297 Mariner
Postby redgin6 » August 20th, 2018, 12:44 pm
I'm sorry guys I'm new to this form I'm trying to get the window out of my 1989 3297 mariner. So I can replace the one that's cracked. How did you fine those rubber trim pieces in the track? And if you can help that would be great. Bob
quickdecision
Vessel Info: Carver 3807, 1987
Been thanked: 23 times
Postby quickdecision » September 21st, 2018, 6:13 pm
There is a company in Washington, Motion Windows, Peninsular Window . They have built several several windows for me. Very reasonable, and better yet easy to install. And there glass. Use Butyl for sealing.
Ron
