Noisy Starboard transmission...rich engine
Re: Noisy Starboard transmission...rich engine
Are both engines running from the same fuel supply, or is here a tank dedicated to each engine? If you can switch them (on mine it's easy to switch either engine to either tank), then I'd do that and run it for a bit before I dove further into parts.
- 405driver
- Vessel Info: 1998 Carver 405 gas
- Has thanked: 37 times
- Been thanked: 6 times
Now that you mention that, maybe a good look at the fuel filter might be in order...
I don't think just running a little rich would give you liquid fuel in the exhaust... more carbon certainly, but all the liquid should be gone. Just running a little rich wouldn't cause the idle speed to wander all over the place, but a misfire would. Running just a little too lean does cause misfire and unstable idle speed (not saying at all this is your case, but likening the unstable idle to what you're seeing, more than a slightly rich condition).
If that vacuum line was disco'd from the fuel pressure regulator, then that DEFINITELY was causing a slightly rich condition at idle. Might ONLY explain why your old plugs were much darker than they should have been. Knowing that you changed and corrected that, you might want to re-establish all the existing symptoms so you're starting fresh with a diagnosis. What exactly do you know to be true right now based on current observations?
- 405driver
1. The transmission rattles in idle....still true
2. There is still fuel in the exhaust (at idle). A small slick comes to the surface and then immediately disappears.
3. The idle "hunts" slightly as confirmed by listening to the motor and watching the computer. The other engine fluctuates on the computer also, but this engine seems to vary more.
4. The engine starts,runs and accelerates very smoothly. It's just having issues at idle. I don't know if the fuel remains in the exhaust above idle. I will check that tomorrow. Strangely, the IAC computer readings on this engine were twice the readings on the other engine.
I'll know a little more tomorrow after the compression check. (which I'm a little worried about).
If I can figure out how to do it, I'll try to post some screen shots from the computer (maybe a video) and some pictures of the fuel pressure gauge with the vacuum line connected and disconnected.
I'm also going to switch fuel tanks.
Thanks...
- Has thanked: 602 times
- 405driver
There is an old axiom called "Ockumsrazor" that states "the simplist answer is usually the correct one". So, I keep looking for a "simple" answer.
I'll do that today......thank you.
405driver wrote:Source of the post Hey....I appreciate any idea.
Trouble is, that don't work on multiple choice exams methinks........
- 405driver
Was fuel pressure confirmed and compared to spec? I assume so, and that it didn't meat spec, otherwise why is he recommending regulator replacement? Was a fuel pressure gauge left on the rail and checked a while later to see if it maintained pressure? Was a cylinder drop test done?
Did anybody ever suggest hooking up a vacuum gauge?
Was there a determination made regarding the IAC reading?
While the diagnostic tool was hooked up, what was the voltage reading?
Besides the IAC reading, were there any other sensor readings that stood out? Was the engine hot when the diagnostic tool was hooked up? Does this (fuel in water) continue when the engine is hot at idle? What was the temp reading on the diagnostic tool? Does the oil smell like fuel? Is it at the correct level?
