Getting glue from shrink tape of window and boat
Topic author
Paradise II
Vessel Info: 1985 Carver Mariner 36
Postby Paradise II » April 29th, 2017, 7:20 am
I have a 85 Mariner 36 and I have had it in the lot for 7 weeks getting the bottom painted. Because of some leaking around the windows we used some heat shrink tape. The tape took care of the leaking but after taking it off, I have the glue residue left and have found nothing that will get it off. It is on the boat and the aluminum window frame. Any suggestions to getting it off without hurting the windows or the gel coat. Thank you
Re: Getting glue from shrink tape of window and boat
Postby tomschauer » April 29th, 2017, 9:50 am
3m heavy duty adhesive remover. It wont hurt your gel.
Topic author
Paradise II
Postby Paradise II » April 29th, 2017, 4:42 pm
thank you
Been thanked: 248 times
Postby mjk1040 » April 29th, 2017, 7:24 pm
Acetone?
Been thanked: 1112 times
Postby km1125 » April 29th, 2017, 7:46 pm
I'd be careful with acetone on anything that might be painted, if the aluminum frame is.
You might also try car wax. I had duct tape goo on a bike once and car wax took it all off easily.
Postby Viper » April 29th, 2017, 8:15 pm
I use Bio Breakdown adhesive and mastic remover. Works great.
http://www.citrus-adhesive-remover.com/bio-breakdown.html
By the way, you never use shrink wrap tape on anything other than shrink wrap. If you're taping the wrap off to anything, you should use Preservation Tape, it's specifically designed for that and will not leave a glue residue.
Ondercin
Vessel Info: 1988 carver 3607 AFT
Penetanguishene
Has thanked: 2 times
Been thanked: 3 times
Postby Ondercin » April 29th, 2017, 9:41 pm
WD-40
Penetanguishene
throwback2
Vessel Info: 1987 Carver 28 Voyager,twin small blocks,1991 Shamrock,350 Chevy now.
and a few other water toys
Has thanked: 8 times
Been thanked: 23 times
Postby throwback2 » April 30th, 2017, 8:51 am
WD-40 x2
Postby mjk1040 » May 2nd, 2017, 6:38 pm
Thanks all, I had the same question!
feeez
Vessel Info: 2001 350 Mariner
Has thanked: 52 times
Been thanked: 66 times
Postby feeez » May 2nd, 2017, 11:01 pm
Purell hand sanitizer sometimes is an nice gentle way to remove gummy residue..... worked on tree sap on my truck.
Cheers
Fraser
Former 2001 350 Mariner owner
Users browsing this forum: No registered users and 45 guests
