Draining Racor filter
Makin Waves
Vessel Info: 2006 Carver 46MY
Been thanked: 8 times
Postby Makin Waves » October 14th, 2017, 4:33 pm
When I was winterizing I saw water in the glass bowl on one racor filter. I drained the water and it looks like it filled with fuel
I will not start engines until spring, Volvo TAMD 75 EDC 2006 Caver 46MY. I drained the filter after I winterized the engine
Did I drain water correctly by just using the drain valve at the bottom?
I will change filter elements in spring
Dave
Re: Draining Racor filter
Postby Midnightsun » October 14th, 2017, 5:28 pm
Yep, that is how it should be done. :beergood:
Postby Viper » October 14th, 2017, 7:47 pm
Before you leave it for the winter, make sure that valve isn't leaking now or you'll be in for a surprise in the spring. I've had some leak from draining after they haven't been used for years.
Makin Waves
Postby Makin Waves » October 14th, 2017, 8:10 pm
thanks
Makin Waves
thanks
Users browsing this forum: No registered users and 9 guests
