Kohler generator for dummies, questions
glazingguru
Topic author - Scurvy Dog
- Vessel Info: 1995 Carver 355 Aft Cabin
Because we are usually in the slip when we need power, I have yet to need my generator. I have started it a few times and will make a habit out of starting it more often. I realized that although I started it, I had put no load on it. The instructions I have are vague as far as how to start and use it. I switch the shore power to off and start it, then I flip the breaker switch on the generator to on and now what? I dont see anything happen and no sign of electrical power. Can anyone give me step by step instructions? I feel kind of dumb here.
- Lyndon670
- Has thanked: 124 times
- Been thanked: 140 times
Re: Kohler generator for dummies, questions
It is very easy to do, start by turning on your blowers. Once you are comfortable that the vapours are out, hold the toggle (or turn the switch) to the 'start" position. Once you here the genny is running, return the switch/toggle ro the "run" position. Now you will also see a switch on your AC panel that says "SHORE" or GENERATOR. It is set up that the switch can't be in the same position (Shore and Generator) at the same time. Flick the switch to the "Generator" setting. You may have a faulty AC meter on the panel, so don't count on the reliability of its readings. Plug a nightlight into an outlet that you can see from the panel.
If none of this works, there is 2 switches/breakers on the genny. One is a start switch and the other is a breaker that will run the power to the panel.
If this doesn't work, you may have to have a marine electrician to look at it.
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
glazingguru
eric_b
- Vessel Info: 1986 Carver 3227 Convertible
Real Simple....
- Tommyfmu
- Vessel Info: 1996 Carver 325 Aft Cabin Motoryacht
- Has thanked: 1 time
- Been thanked: 2 times
- Contact:
- Been thanked: 654 times
glazingguru wrote:Hi,
are you opening the engine hatch each time and flipping it on the genset? once you know that the breaker on the genset is on you dont need to switch it off each time you run it just leave it alone. following the above instructions with starting and turning the ship/shore switch to ship(generator)also make sure the main breakers on the panel are on mine will usually flip off when turning the ship /shore switch verify they are on with the genset running. if you have movement on the ac panel meters when at the dock you will see them operate on the genset. also i dont know how long you've had your boat, but did the genset develop power when you had a survey? or anytime?
glazingguru
- 4mo
Thanks!
If you don't use it often, try replacing the raw water impeller, it may be that simple. If not let us know.
- Has thanked: 602 times
- Been thanked: 1310 times
4mo wrote:Source of the post This site is great, first night out on our 370 and the generator was working but the load switch on the generator wasn't on. 2 minutes online and my wife thinks I'm competent.
Thanks!
And the admiral is correct....
Users browsing this forum: Google Adsense [Bot] and 24 guests
