My Season Is Over
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
My Season Is Over
The marina mechanic will winterize my engines and A/C. Then I will make an appointment to get her shrinkwrapped.
Now I will begin counting down the days to launch. I will launch as early in April as I can. I want to get the hull buffed and polished prior to launch if I can. Hope that the weather will be good enough in April for the job to get done then back into the water for 2018.
Golfgippsland
- Vessel Info: 1989 Santego 2767 mid cabin express
- Been thanked: 2 times
Re: My Season Is Over
1989 Carver 2767 Santego
1971 v156 glastron modified
1985 whittley cruisemaster
1982 2950 Bayliner offshore express
- RGrew176
Golfgippsland wrote:Source of the post Hi just wondering how much it costs to winterize and shrink wrap your boat. Just curious as this is not done in Australia.
I will be glad to give you an answer once the winterizing process is completed.
- RGrew176
- feeez
- Has thanked: 52 times
- Been thanked: 66 times
If I was just to walk away from my boat at the end of the season and have the marina do everything, I would get an invoice for around $CDN2500
Cheers..... Where is my
Fraser
- denpooch
- Has thanked: 85 times
- Been thanked: 89 times
I just received a $925.00 bill for my 36 Mariner ($25.00/ft) and I was gonna complain. However, after comparing the job to other boats at both this and other marinas, I decided that it was worth the extra cost.
The yard brought the shrink-wrap material all the way down to the waterline. Usually the material ends just under the toe rail, leaving the sides of the hull exposed. They had to use a bunch of material to cover from the radar arch down to the pin stripes above the paint...stern to bow. (the radar dome and pole mount was wrapped separately). This approach certainly increases the cost.
In my mind, the boat is very well protected leaving just the running gear exposed to the elements.
But still....... $925.00!!!!!
- Has thanked: 602 times
- Been thanked: 1310 times
denpooch wrote:Source of the post In my neck of the woods (Nassau County, NY), the price for shrink wrapping at a marina starts around $17/ft. and goes up from there.
Definitely getting up there, sounds like a nice job though........curious, how many vents did they install in yours???.........they keep delaying putting vents in mine ( paid about the same as you after exchange), been wrapped for over a month and this is when we hit the dew point more often.
