Carver 445
- Mystic144
- Has thanked: 1 time
- Been thanked: 2 times
Carver 445
Do these boats come from Carver with a isolation transformer?
And where is it located?
- AaHubb
- Vessel Info: '99 404 CPMY
- Has thanked: 15 times
- Been thanked: 61 times
Re: Carver 445
..Aaron
SeaDragon
- Been thanked: 1312 times
Re: Carver 445
here is a link to the specs for your model boat......http://www.carveryachts.com/media/5160/ ... -my_99.pdf
- Mystic144
Re: Carver 445
My understanding is the isolation transformer/booster help boost and maintain proper or close to proper voltage, thus protecting sensitive electronics such as the AC units that do not like voltage much below 95 volts.
It also protests the 110 v refrigerator and microwave again neither of which do not like low voltage.
- Has thanked: 474 times
Re: Carver 445
Mystic144 wrote:Source of the post.....My understanding is the isolation transformer/booster help boost and maintain proper or close to proper voltage......
Only if it's an isolator/booster (isoboost). If it's just an isolation transformer, it's only designed to isolate ship's AC from shore power AC in that there is no direct electrical connection, rather it's an electromagnetic connection through a transformer. This eliminates the need for galvanic isolators because it isolates the grounds anyway, reduces the risk of electrical shock in the water, etc. Since a galvanic isolator is standard equipment, I don't think they would install an isolation transformer also unless there was a specific request for an isolation transformer only when she was built. And as mentioned above, you never know what a previous owner might have installed later.
