Recessed light trim rings 350 Mariner
Topic author
anothernewb
Vessel Info: 2000 350 Mariner
Twin Mercruiser 5.7l Horizon
Garmin 4212
Been thanked: 21 times
Postby anothernewb » October 12th, 2017, 11:07 pm
I was hoping someone could point me in the right direction to find suitable replacement trim rings for the recessed lighting on my 2000 350 Mariner. So far I have figured out that the light fixtures are Hera E1 and they have discontinued the lights and parts. I did find https://www.eclectic-ware.com/hera-lighting/er1-es1-ecoline-halogen-lights-and-kits.html still sells new fixtures with trim rings but they don't have any parts anymore. Anyone know where I can find these without buying a $22 fixture?
Dewmyster
Vessel Info: 1998 370 Voyager
Been thanked: 12 times
Re: Recessed light trim rings 350 Mariner
Postby Dewmyster » October 13th, 2017, 6:07 am
I bought the entire fixture, 3 of them! Wish I had just swapped them all to LEDs.
:usa:
Been thanked: 653 times
Postby g36 » October 13th, 2017, 9:59 am
sorry but most likely you wont. these parts are pretty much non existant now, ebay a few cabinet shops to check etc. but i also have a friend thats has asked me to search so i'll be looking too, there may be a chance to save over the $22 each price i did find fixture price of $13 so thats better, i am sure depends on what you want to do . repair or replace. i have made a few calls this morning for parts and will update you on what i find out. luckily my 405 was not used often i did not have to replace any decor rings but i did order some decor rings for back up just in case a couple years ago when the eclectic-ware.com website had them. i did immediately change all over to led bulbs so not to ruin the oem fixtures from the heat from the halogen bulbs. my thought if you have some that are still good is to consolidate them into areas of your boat like a cabin or salon and then if you have to replace with something else the new would be more localized and match fixtures of the same areas.
there is also another post currently about these and a link to a replacement that another member had installed.
650Guy
370 Cummins
Been thanked: 40 times
Postby 650Guy » January 12th, 2018, 8:11 pm
I'm knee deep in this same project now. The 350 mariner has some 14 of these fixtures. Replacing a couple simply will look bad, so I'm faced with the price venture of swapping them all. I'm looking to swap to LED's. I have a lot of concerns.
**LED's do not list watt comparisons so how do I know if they will be bright enough?
**Will they mount in the same hole?
**Is there some inverter that I need to make sure I swap out, or its compatible with?
Just don't want to drop 700 bucks and find out they do not work. Ya know?
Been thanked: 1310 times
Postby bud37 » January 12th, 2018, 8:55 pm
A search on this site should answer your questions, we have been thru it in detail, there are retrofits for less that fit perfect that can be done for a fraction of what you mentioned....lots of info and links....I changed all mine, easy....check it out....... :beergood:
650Guy
370 Cummins
Postby 650Guy » January 13th, 2018, 8:51 am
Thank you very much! I found the list you are speaking of and have opted for the Warm White "Dream Lights" from amazon. Ordered my first batch of 10 lights that should arrive Monday!! YEAH!!!!
This forum is a savior!!!
:beergood:
Gtaylor
Vessel Info: 37 Carver, twin cummins 330 diesels
Has thanked: 2 times
Postby Gtaylor » August 7th, 2018, 1:17 pm
In my 37,I recently had 4 out of 7 of the halogen lights on one circuit go off. The other 3 work. Any ideas on what happened and how to fix?
amanphoto
Has thanked: 3 times
Postby amanphoto » August 7th, 2018, 8:28 pm
The trim rings are all sold out. You can replace the entire light fixture with these LED's. The screw holes line up and are much brighter. They look awesome. Go with Warm White Led to match the tungsten bulbs your replacing.
https://www.ebay.com/itm/10x12V-2-75-LE ... 2749.l2649
Users browsing this forum: No registered users and 123 guests
