Inverter Noise in VHF
Txcruiser
Vessel Info: 2007 560 Voyager, Volvo D12
Has thanked: 2 times
Been thanked: 2 times
Postby Txcruiser » January 14th, 2014, 1:42 pm
My VHF radio has a loud hum that disappears when I turn off the inverter. There is a filter on the DC side to my radio. Any ideas?
Txcruiser
2007 Carver 560
AaHubb
Vessel Info: '99 404 CPMY
my twin diesel pusher
Has thanked: 15 times
Been thanked: 61 times
Re: Inverter Noise in VHF
Postby AaHubb » January 14th, 2014, 8:28 pm
It could be RF interference from the inverter itself. Or there could be an AC power line close to the antenna lead. If the inverter has a metal case try connecting it to your ships ground. One way to determine if the problem is on the power or ant. lead would be to disconnect the ant. while the hum is present. if the hum is reduced or goes away then it is an RF problem. Note.. DO NOT transmit without the ant. connected.
Good luck ... Aaron
'99 404 CPMY
SeaDragon
Txcruiser
Postby Txcruiser » January 27th, 2014, 1:03 pm
Not sure if I ever acknowledged your suggestions. I will have try these once I get back on the boat. Thanks,
claudex
Vessel Info: Carver 366 Motoryacht Diesel Volvo 2004
Postby claudex » March 5th, 2014, 8:15 pm
Hi Txcruiser,
The most likely cause is the inverter itself.
First disconnect all loads from the inverter. unplug all loads and not just switch them off.
If the hum persists it is the inverter and it needs replacing.
What is the make of the inverter and size.??
Adding filters is not in my opinion the way to go.
Return to “Electrical”
