Prop sizing
- Fallguy87
- Vessel Info: 1978 carver santa cruz 28. Twin 302 fords.
- Has thanked: 3 times
Prop sizing
- Has thanked: 550 times
- Been thanked: 1145 times
Re: Prop sizing
- Fallguy87
Re: Prop sizing
- Has thanked: 59 times
- Been thanked: 970 times
Re: Prop sizing
How much clearance do you have from the prop tips to the hull?
1996 Boston Whaler Rage 15 - Location: Saint Joseph,Mi
- Has thanked: 50 times
- Been thanked: 399 times
Re: Prop sizing
Smaller prop means more rpms. Larger prop means less rpms.
Re: Prop sizing
Re: Prop sizing
Fallguy87 wrote:Source of the post Morning all. I have 2 rebuilt strong 302 ford's. The boat runs at 18 mph gps speed at 3600 rpm. Pretty sure from what I've read that's way to high engine speed. Gets on plane in seconds. I'm guessing.... maybe closer to 15x15???? Does anyone know what the factory was?
You're in luck ...found this, but is from a 1980...probably close to yours...check it out...performance data and all......
http://www.carveryachts.com/media/4691/ ... ruz_80.pdf
Re: Prop sizing
bud37 wrote:Source of the postFallguy87 wrote:Source of the post Morning all. I have 2 rebuilt strong 302 ford's. The boat runs at 18 mph gps speed at 3600 rpm. Pretty sure from what I've read that's way to high engine speed. Gets on plane in seconds. I'm guessing.... maybe closer to 15x15???? Does anyone know what the factory was?
Good starting point, but I think a couple things are interesting.
1) ALL the engine options are specified in HP, EXCEPT the 302.
2) The 220HP and the 302 are both spec'd in the document (twice) as being 1.52:1 ratio transmissions, but in the performance data it lists 220HP engines and 1.46:1 ratio.
The OP has 14x11 and the test boat has 16x15... quite a difference.
Re: Prop sizing
Big difference between 14 x 11 and 16 x 15.
If it has 3 blade props and they are actually that small, there are other problems.
- RGrew176
- Vessel Info: 2022 Stingray 182 SC
- Has thanked: 72 times
- Been thanked: 464 times
Re: Prop sizing
Users browsing this forum: Google [Bot] and 63 guests
