2000 356 propeller shaft size
AnamCara
Vessel Info: 2000 356
Crusader 7.4L MPI
7.3kw Kohler
Has thanked: 10 times
Postby AnamCara » March 12th, 2018, 4:37 pm
Does anyone know the propeller shaft size on a 2000 356 with 7.4l Crusaders?
Re: 2000 356 propeller shaft size
Postby tomschauer » March 12th, 2018, 5:55 pm
My 355 with 7.4's has 1 3/8 shafts.
AnamCara
Crusader 7.4L MPI
7.3kw Kohler
Postby AnamCara » March 12th, 2018, 9:01 pm
Thanks fro the quick reply, I was looking up specs on the boat and it states that they should be 1 3/8 . I stopped down to a marina by home and measured the shafts on a 355 and a 356 both with Merc's and they were both 1.5 in. I guess I'll have to wait to check the boat itself, only problem its 5 hours away.
Postby bud37 » March 12th, 2018, 9:20 pm
AnamCara wrote:Source of the post Thanks fro the quick reply, I was looking up specs on the boat and it states that they should be 1 3/8 . I stopped down to a marina by home and measured the shafts on a 355 and a 356 both with Merc's and they were both 1.5 in. I guess I'll have to wait to check the boat itself, only problem its 5 hours away.
Did you notice the years on the ones you measured??.....reason I ask is that on the Mariners they upped the shaft size there from about 98 or so to the 2001 that I have....not sayin for sure but possible in the 355/356 model as well........ :popcorn:
Postby km1125 » March 13th, 2018, 9:55 am
You should send an email to Carver... I'm sure they'd know what they spec'd for the different engine combinations.
I looked in a parts manual for a 2002 356 and was surprised I didn't see the shafts or props mentioned anywhere. Thought I'd see a table of the various combinations based on engine options.
AnamCara
Crusader 7.4L MPI
7.3kw Kohler
Postby AnamCara » March 13th, 2018, 9:13 pm
The 2 boats I looked at were a 1998 355 and a 2001 356. Both with 1.5 in shafts
Postby tomschauer » March 13th, 2018, 11:50 pm
I need new zincs this year, I better check my shafts before ordering. Everything I have says 1 3/8" but it sounds like that may be incorrect.
Thanks all.
jcoll
Vessel Info: 1998 355 Motor yacht
Has thanked: 18 times
Been thanked: 18 times
Postby jcoll » March 14th, 2018, 6:25 pm
My '98 355 with Crusader 454's has 1 1/2" dia. shafts.
Samuel
Postby Samuel » March 27th, 2018, 4:01 am
i am having work done its 1 1/2 inches. That is what you need in zinc size to.
Postby tomschauer » March 27th, 2018, 10:05 am
Yep, I confirmed last weekend that my shafts are indeed 1.5"
