Water tank issue....
Topic author
SharonAnne
Vessel Info: 1989 Carver Montego Mid Cabin 2557
Postby SharonAnne » May 28th, 2018, 7:53 am
I have a 1989 Carver Montego 2557. Just got her in the water and have an issue with my water freshwater. I filled the water tank but no water is coming out of faucets. The toilet is filling and flush-able. I can hear the water pump making noise. Where is the water going? Must be a leak somewhere? Any suggestions?
Has thanked: 585 times
Been thanked: 1242 times
Re: Water tank issue....
Postby bud37 » May 28th, 2018, 7:57 am
Have you got a hot water tank, if so may it may be just be filling that,check the fittings at the water tank,maybe they never got reconnected...... make sure you have a hot water valve open somewhere to help remove the air from the tank......clean all the faucet screens at the taps......its a start, go from there....
FWIW.....The above is just my opinion..... :popcorn:
Has thanked: 270 times
Been thanked: 1164 times
Postby Midnightsun » May 28th, 2018, 8:08 am
Who winterized the system? Did they disconnect something? Was the heater drain valve left open? Look around for water accumulating in the bilge. If all of the previous is no then the pump may be on its way out not being able to self prime and yes all water pumps we use in our boats are self priming.
Topic author
SharonAnne
Postby SharonAnne » May 28th, 2018, 1:43 pm
There is water coming into the bilge. There is no hot water heater. Where the heck is my water tank? I can't find where the water hose connects.
Has thanked: 325 times
Been thanked: 595 times
Postby tomschauer » May 29th, 2018, 8:23 am
on the 2757 the water tank is under the bed in the aft cabin. Check there.
buster53
Vessel Info: 2001, Carver 356
Been thanked: 262 times
Postby buster53 » May 30th, 2018, 9:23 am
SharonAnne wrote:There is water coming into the bilge. There is no hot water heater. Where the heck is my water tank? I can't find where the water hose connects.
Are you sure there is no water heater? Not trying to give you a hard time, but if you can't find your water tank, you are really going to have trouble finding a water heater as it is much smaller.
buster53
Postby buster53 » May 30th, 2018, 9:26 am
SharonAnne wrote:Source of the post I have a 1989 Carver Montego 2557. Just got her in the water and have an issue with my water freshwater. I filled the water tank but no water is coming out of faucets. The toilet is filling and flush-able. I can hear the water pump making noise. Where is the water going? Must be a leak somewhere? Any suggestions?
OK, the toilet (head) is flushing. Do you have fresh water or raw water flush? I'm guessing a Carver of that vintage probably has raw water flushing unless a previous owner switched it over.
Topic author
SharonAnne
Postby SharonAnne » May 30th, 2018, 3:01 pm
Thanks all. I have someone coming to look at it next week. Meanwhile, I'll look at hose and tank.
Users browsing this forum: GBoater and 55 guests
