Window channel replacement
Polarman
Vessel Info: Metanoia - 1993 Carver 370 Aft Cabin. Twin 7.4 L Crusaders.
Postby Polarman » July 10th, 2018, 8:21 pm
We have recently purchased C 370 Aft Cabin. (1993). The window channels in the salon and the aft stateroom are deteriorated and mossy. Where can I find replacements and what should we know before we attempt to replace them. Thanks.
rjr
Vessel Info: 440 MY
Has thanked: 25 times
Been thanked: 9 times
Re: Window channel replacement
Postby rjr » July 10th, 2018, 8:59 pm
Polar - We have same situation. I obtained some info from Taylor Made Systems. Doesn't spell out the process but is helpful nonetheless. Will share - send me message with your email.
Polarman
Postby Polarman » July 10th, 2018, 9:05 pm
Polarman
Postby Polarman » July 10th, 2018, 9:39 pm
Not sure best way to get this to you. Still new at this blog. Seems like an older format. Please contact me at mike@upnorthpowersports.com
Thx
Sonofdivver
Vessel Info: 1995 430 Cockpit Motor Yacht
Postby Sonofdivver » August 2nd, 2018, 10:10 pm
I'm about the same situation with my 430 cockpit motoryacht.. Could you please forward the information to me as well? Dallenjr@sc.rr.com I really appreciate it.
1995 430 CPMY
315 Cummins
Home Port: Little River SC
ronmar
Vessel Info: 1993 350 Aft Cabin
Has thanked: 21 times
Postby ronmar » August 6th, 2018, 11:11 pm
I as well have same issues on a 93 350 Aft Cabin. Would love to know how to replace. I'm having some leaking issues and think possibly the cause.
Liechtenstein
chpsk8
Has thanked: 27 times
Been thanked: 76 times
Postby chpsk8 » September 15th, 2018, 7:28 pm
If someone has the info on replacing that weatherstripping and could post the process that would be awesome. I believe it's called schlagel or something like that.
I'm wondering if the windows have to be split in order to install it.
Mine are mossy, which I was able to clean out, but also bits are missing.
quickdecision
Vessel Info: Carver 3807, 1987
Been thanked: 23 times
Postby quickdecision » September 16th, 2018, 8:45 am
Just finished rebuilding the salon windows in a 3807. Bottle jack and 2 x 4"s allowed windows to be removed easily. Frames removed, cleaned, repainted. Re-bedded with butyl. Do not tighten screws all the way at first. Use 1/8" spacers. After about 2/3 weeks pull spacers and snug screws the rest of the way. Installed slick tape in the bottoms of the channels. This made the windows slide with one finger. DK hardware has the weather seals that seals the windows to the tracks. Make sure you clean the drain holes in the window frames. This is a major cause of leaks. Below are the companies that supplied the materials. Butyl can be bought from many sources. This is the material used to seal you car windshield in.
Ron
http://www.eplastics.com/slick_strips
http://www.dkhardware.com
1992330aftcabin
Vessel Info: 1992 330 Carver aft cabin
Has thanked: 54 times
Been thanked: 32 times
Postby 1992330aftcabin » February 16th, 2019, 6:25 am
rjr wrote:Source of the post Polar - We have same situation. I obtained some info from Taylor Made Systems. Doesn't spell out the process but is helpful nonetheless. Will share - send me message with your email.
I have the same issue, can you share the info from Taylor? Mikelarson1959@gmail.com thanks Mike.
StDuckie
Vessel Info: 1991 3607 Aft Cabin Cummins 6BTA
Has thanked: 29 times
Postby StDuckie » August 18th, 2019, 9:26 am
Hello all, I too have Taylor Made windows...please share procedure for replacing sliding window channel. Thanks to all. Doug :beergood:
Users browsing this forum: No registered users and 58 guests
