Overheating 6.5k kohler Gen resolved
Wkuhilltopperfan
Vessel Info: 1998. Mariner 350 . Twin 7.4 engines / kholer 6.5 gas Genset
Has thanked: 17 times
Been thanked: 18 times
Postby Wkuhilltopperfan » July 22nd, 2018, 4:31 pm
Hey guys and gals! I live in a area where the waters can get up in the 90’s and it’s caused Generator overheating shutting down year after year for me in my 350 Mariner. I’ve been told that the factory heat exchanger was just not big enough for water this warm. I purchased a secondary water to water heat exchanger which I located outside of the generator housing, this not only allowed for a better cooling it also added almost another 1/2 gallon of antifreeze to the closed loop system. I’ll attach a few photos and the results I got .... I was very excited with a 70 deg reduction in heat and that was before the water hit the factory heat exchanger.
1998 350 Mariner
Re: Overheating 6.5k kohler Gen resolved
Postby Midnightsun » July 22nd, 2018, 5:10 pm
Thanks for the thorough write up. It's posts like this that make our forum so valuable to all. :clap:
Wkuhilltopperfan
Postby Wkuhilltopperfan » July 22nd, 2018, 5:29 pm
Midnightsun wrote:Source of the post Thanks for the thorough write up. It's posts like this that make our forum so valuable to all. :clap:
I know I have alway appreciated others making post like this, us do it yourselfers need this stuff lol . Thanks for the kind words
1998 350 Mariner
Postby km1125 » July 22nd, 2018, 9:37 pm
Is that the actual sea water temperature you're measuring and it dropped from 167F to 96F??
Wkuhilltopperfan
Postby Wkuhilltopperfan » July 22nd, 2018, 10:45 pm
km1125 wrote:Source of the post Is that the actual sea water temperature you're measuring and it dropped from 167F to 96F??
The water temp coming out of the generator was 167 and after it came out of the new heat exchanger I installed it had cooled back down to 97 before it went back into the generator. I took the water temp this morning and it was 88 degrees after all the rain we have had. So it’s pulling the water temperature down to within 10 degrees of the lake water. Just remember this is a closed loop system that uses antifreeze and only uses the lake or sea water to pull the heat away from the generator. Some generator setups only use lake or sea water for all cooling
1998 350 Mariner
Virgin Islands (USA)
cordesjoanne
Postby cordesjoanne » July 23rd, 2018, 6:08 am
You can get the best advice from the generator and engine study expert from CSDG - http://csdieselgenerators.com/contact-us/
Postby Viper » July 23rd, 2018, 6:44 am
:clap:
