Transmission fluid change
nazinteck
- Vessel Info: 1997 325 Carver Aft with twin Gas TB350 XLi engines
- Has thanked: 16 times
- Been thanked: 5 times
Re: Transmission fluid change
- Has thanked: 602 times
If you want to err on the side of safety , e mail Borg warner with yours trans type, year and serial number and ask them what fluid to use and the fluid change procedure if any.
nazinteck
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
nazinteck
Other than the vent, the transmissions and gears are pretty much sealed up.
km1125 wrote:Source of the post I cannot imagine having the change out the transmission fluid every year. That seems pretty excessive to me. Engine oil makes a lot of sense, because it is constantly getting bombarded with combustion products and the high under-piston temperatures. You also get moisture from those combustion products.
I am thinking the same. I do know my Volvo transmissions are supposed to be changed every year or 200 hrs which is rather too often if you ask me. They also say to change the filter however the filter is a medium washable stainless steel wire mesh! These are washable and not supposed to be changed, just cleaned. Regardless, when I did do the change the oil was like new and the filter also. Oil even smelled like new. I am pretty sure it was 10 year old oil and the original filter. I will probably be changing every couple or 3 years from now on.
- RGrew176
